wnjj
Jan 04, 2016Explorer II
Joe417 wrote:
If you put oil in the oil holes that are in the crank handle opening as advised by Happijac, some of it end up inside just as pouring it down the gears with the electric motor removed.
Extra oil shouldn't cause an issue like this. The old Johnson and Evinrude electric transmission used this type of design but submerged it in oil and it worked great.
I could see where something under the spring could be a problem or the shaft surface under the friction spring could get worn or the spring get broken could possibly be a factor.
Speculation...................
Happijac recommends "a few drops of light oil" which is different than "pouring a little 30W". I don't know enough about the cinch spring one-way design and you may be right. It may well work fine submerged in oil. Clearly, though, something is wrong with the OP's jacks and it seems unlikely that 2 of them have broken springs (though not impossible).
If they were mine, I'd have them apart to see what's going on there.
44,056 PostsLatest Activity: Nov 19, 2013
