covered_wagonExplorerJan 03, 2016Surprising Danger experienced With My HappiJacksThe circuit board went bad on my Happijacks so I had to switch to manual use using the crank. This essentially disengages the electric motor from the gears allowing manual use of the hand crank to the...Show More
billtexExplorer IIJan 04, 2016The HJ manual does say to be sure to "release lock when cranking/re-set lock when not cranking". OP did not say if he followed this procedure...Clickety
Related ContentSurprisedHappijack BedGlow plug replacement Pleasant surpriseNeed help from experienced woodworkerUnpleasantly Surprised
