otrfun wrote:
TX and CA (and other states) use the GVWR and/or GCWR of various RV's (motorhomes, TV's and trailers) to determine whether a state issued Class A/B/C (non-DOT) license is necessary. It would seem, at least in some states, the DMV and law enforcement view GVWR/GCWR as a bit more than arbitrary and/or a "warranty number".
Now you understand exactly WHY manufacturers offer a 3/4 ton truck, as opposed to a 1 ton truck. They do it because of arbitrary numbers like California and Texas deciding that a truck OVER 10,000 lbs is commercial, whereas a truck at or below 10,000 lbs is not commercial. There is very little mechanical difference between the two vehicles (assuming SRW only)... but one is arbitrarily given a 10,000 max GVWR simply to comply with the weight designation of certain states.
You are proving my point. All these numbers just mean a different level of tax from each state. These states require a more expensive registration fee, or a more expensive license for trucks over being over 10,000 lbs. It doesn't make the one vehicle more or less capable than the other... it just allows the state to collect more money for allowing you the privilege to drive it.
By the way, just one more example to prove that they are arbitrary... I live in Maryland. Maryland allows me to register any vehicle for any weight that I want, I just have to pay a higher tax/registration fee for that higher weight. I can register a Ford Ranger for 12,000 lbs GVWR if I want to. If I put E rated tires and wheels with a load capacity of at least 3000 lbs on my Ranger, I can legally load that Ranger down to 16K lbs. I can then figure out a way to load a heavy 5th wheel on that Ranger and drive it through California on my regular non-commercial class A license which rates me to drive any non commercial vehicle and any non commercial trailer.
While incredibly stupid to do so, California couldn't do a darn thing about it. I'm under the federal bridge limits of 20K per axle, I'm under my registered weight of 12K lbs and I'm under my tire rate of 12K lbs. This is all hyperbole, mind you, because the Ranger likely wouldn't make it out of my driveway without falling apart, but my point is that it would be PERFECTLY LEGAL.
