SoundGuy
Jun 21, 2015Explorer
We Cant Wait wrote:
If it's a case of the truck not setting level and sagging too much in the rear then you're equalizer hitch is probably not properly adjusted.
I'll bet the OP is asking about air bags because he's not even using or planning to use a properly sized and adjusted weight distribution system. :E If so, he obviously needs to do more research on the proper equipment required to tow a trailer of this size with his truck, otherwise he'd be asking about WD and not air bags. ;)
