path1
Sep 09, 2015Explorer
Suspension question
(2001 dodge 3/4 ton with 8 foot bed, 2 wheel drive, 8,500 pd trailer)
Still bottoming out in the front end. Not nearly as much as before after I put air bags in the rear. Air bags took out probably 95%.
Mostly at freeway speed on rough road or the bump coming off a bridge. I'm going to replace the original shocks that are 15 years old with 90,000 miles on them.
Is there any shock that would NOT raise the height but would solve front ending bottoming out?
Other options that I see are heavier springs, but adds height, don't want that. I see rubber cushions, don't know if they are any good or not.
If you've had this problem, how did you solve it?
Thanks
Thanks
