deserteagle56 wrote:
Even with swing-out brackets my Bigfoot would not fit on my Ram dually. I had to add a 4" extension, but the way the brackets work on the Bigfoot I had to use 4" channel. Otherwise, the jacks would not lock into the open or closed position.
With that much extension I still have only about 1" clearance on each side for the fenders.
I looked today and 3" is just about max because of the length of the jack motor cable. Unless I could mod the cable length. Then I'd have trouble when I moved the jacks to the inboard position.
I have a 2003 Lance lite 1025 and from the pics it's the same setup as NRALIFR. I'd be happier with even more clearance but when I loaded the other day it was an inch or less. That's just too tight.
