time2roll
Jul 05, 2020Nomad
GravelRider wrote:Absolutely never use the 12v fridge mode when a continuous power source is not available.
in the morning with our voltage reading at 11.4 volts. To be fair, our 12 volt fridge was running at the time, so I'd imagine actual voltage was probably 11.6 or so, but still too low for my tastes, and for good battery longevity.
Assuming you are running a generator to recharge the battery... verify your charging voltage is 14.2+ volts on the battery. If not you need a new converter.
Fix these issues before you swap batteries.
44,071 PostsLatest Activity: Aug 16, 2026
