CA_Traveler
Jul 06, 2020Explorer III
My Trimetric shows voltage, amps and % Full plus other options. Or in the menu system you can get a lot of additional information . Many also use the Victon.
Voltage is limited in determining battery usage. These meters track all amps in and out and voltage and comppute the battery SOC. They use a shunt (very low ohm precision resistor) connected close to the battery to obtain this information. I use a 500A 50mV shunt so there is absolutely no concern about voltage drop.
44,071 PostsLatest Activity: Aug 16, 2026
