Huntindog
Mar 13, 2021Explorer
CavemanCharlie wrote:Probably with some creative modding it could be made to work... BUT it probably would be a waste of time. The reason for a CAT heater is to eliminate the draw from the fan. Installing a fan that would move enough air to make a difference would put you back where you started from.Vintage465 wrote:crosscheck wrote:Vintage465 wrote:crosscheck wrote:bpounds wrote:
Couple things to add,
That 12v fridge is bad news for boondocking. They are very inefficient. Normally only find those in popup style rigs. But, I guess you're stuck with it. Get more battery.
I like the Vmax line of 6vdc. And with those AGM, you do not need to put them in a battery box. They are safe in any orientation. That might allow you to get even more than 2 of them, but you do need pairs. Unless you look at the Vmax 12vdc AGM. I don't have the 12v, but I would trust the name.
The cheap club store batteries will need to be in a box, and you'll likely end up replacing them sooner. Depending on how you maintain them. Might or might not be worth the savings to you.
One of the main reasons I chose a Danfos compressor style 12V fridge /freezer was because the they are a favourite of the ultimate boondockers which are yachters. They can't use propane fridges because propane is heavier than air and could sink to the lower decks if there was a leak and could cause an explosion.
Our camping style is 98% dry/boondock camping. For 5 years, we camped with a 7.5cuft NovaKool fridge/freezer which when cycling used 4.4A. They are more efficient than absorption fridges using 1/3 less energy. They cool much quicker, for the same outer dimensions, have 1/3 more volume, keep more consistant temperatures in hot ambient temperatures and are not a fire hazard. We almost never needed our 2000W genny as we had 4 6V AGM batteries and lots of solar.
People who use the term"12V fridges are bad news for boondocking" have never had this kind of fridge. They are becoming much more popular for so many reasons as long as you figure in more electrical capacity(batteries, solar) if you don't want to run your genny.
I have a 6 cuft absorption fridge in my TT which came with the new unit. If it gives up the ghost down the line, a 9 cuft NovaKool will fit exactly in the same opening and as I already have plenty of solar and 4 6V GC-2 batteries and more room for extra solar, this is the route I will go.
Dave
That does sound like an efficient 12v fridge. My concern as a boon docker is I hate.........did I say hate?.... Generators. I'll do most anything not to use a generator. And I like camping year round. That include weather that gets down in the teens. I'd need enough battery to run my furnace to heat the the belly of the coach to keep the tanks warm enough. I can keep up with my furnace pretty easily with my solar, but I think if you tagged another fairly high draw unit on the 4-6v's it'd get critical. Bottom line is you really have to prioritize your usage choice. I want a furnace, a C-pap, no genny and winter. Prolly nixes the 12v fridge...for my boon docking needs.
Howdy, to another Creekside owner. Another neat plus for compressor fridges is that they can be operational without problems out of level for long periods of time.( Again, think of yachts).
No question, the NovaKool was the largest single draw of battery power bar none.So if you had to choose, get rid of the OEM heater fan and put in a Cat heater. I have no experience with these but some say they work well.
My absorption fridge works fine but I would replace it in a heart beat if it quit.
Dave
Problem with the CAT heater will not heat the belly in real cold weather. I personally am big fan of propane fridges. I don't see any reason to use anything different. I've also found, as I get older, that there are an alarming number of people that really don't care what my opinion is! Everyone will use what they need that fits their use needs.
Sorry to jump in on the middle of your conversation. Could a person use a CAT heater and a 12 volt fan to push heat into the underbelly ? I've often wonder d about this.
I too love my propane fridge that I have in my 1993 Travel Trailer and I have no problems with it cooling.
My brother has a 2018 5th wheel and the propane fridge that he has will not keep food cool when he is traveling down the road, or in days when the outside heat is high. I think the newer ones are not built as well and are giving the whole industry a bad reputation.
