pianotuna
Mar 13, 2021Nomad III
Huntindog wrote:
Probably with some creative modding it could be made to work... BUT it probably would be a waste of time. The reason for a CAT heater is to eliminate the draw from the fan. Installing a fan that would move enough air to make a difference would put you back where you started from.
My twindow fans draw a scant 27 watts and solved water line freeze ups. I used them to replace the return air grill for the furnace. I operate them using a mechanical thermostat kept near the water pump.
I won't use a non vented combustion heater, nor a generator when I plan to be sleeping.
