Huntindog
Mar 13, 2021Explorer
pianotuna wrote:Do you think those fans would do as good a job circulating heated air thru the underbelly as the furnace fan?Huntindog wrote:
Probably with some creative modding it could be made to work... BUT it probably would be a waste of time. The reason for a CAT heater is to eliminate the draw from the fan. Installing a fan that would move enough air to make a difference would put you back where you started from.
My twindow fans draw a scant 27 watts and solved water line freeze ups. I used them to replace the return air grill for the furnace. I operate them using a mechanical thermostat kept near the water pump.
I won't use a non vented combustion heater, nor a generator when I plan to be sleeping.
I agree on not using a non vented heater... Even when not planning to sleep. Sometimes those heaters can make one sleepy.
I do use the generator though. It is 75' away, usually behind a tree/fallen log etc.I do not try to conserve energy when cold weather camping. The generator never shuts off.
