pianotuna
Mar 13, 2021Nomad III
Huntindog wrote:
Do you think those fans would do as good a job circulating heated air thru the underbelly as the furnace fan?
I agree on not using a non vented heater... Even when not planning to sleep. Sometimes those heaters can make one sleepy.
I do use the generator though. It is 75' away, usually behind a tree/fallen log etc.
Hi Huntindog,
All I can tell you is they were effective in my class C at -37 C (-34 f).
I was having freeze ups while driving--the furnace was on, but the heat from the cab prevented it from cycling. They do not move nearly as much air as the furnace fan. I've not had a freeze up since 2010.
By unvented heating device, I have, on occasion, when street parking where I was in a convention all day long, run the burners on the stove top at low levels. It was in Calgary, and I had no access to shore power. I did leave the furnace active, but at the lowest possible setting. There was a tremendous blizzard. I would return "home", start the generator, turn up the furnace, turn on electric heaters and run the stove burners flat out. After 2 hours I'd make my supper. Then I'd drive to the nearest gas station, refill the generator, and refill the propane tank. As soon as I was finished fueling, I'd restart the generator. Then back on the streets for another night. I had a Kipor 3000 Ti inverter generator, with electric start. About 10 pm, I'd stop the generator, refuel it, turn on my smallest inverter, and use a heating pad in the bed.
I had an analog cell phone and a dial up isp with a toll free number. The laptop was connect to the cell phone by a device that provided a dial tone. My connection speed was 1/4 regular dial up--but it was good enough to do email--and even streaming audio from the BBC. Web sites were not nearly so data intensive in those days. The cell phone had unlimited minutes after 6 p.m.
75 feet would make it safe to run a generator. Unfortunately, after having one stolen, my generator is bolted in place, and protected by a steel cage. I know it would only slow someone down.
