Looking to change out the T-Stat on the rig any recommendations? 2014 Forest River Micro lite Airxcell 48000 series AC with Suburban gas heat T-Stat says Coleman-Mach on the face
The only thing to watch out for if installing a home t-stat is your 2 speed fan function which may require an extra switch if you want to keep that function. The home units seem to work fine but the wiring on some is a bit different but there are lots of posts on how to do it.
