bravotwo's avatar
bravotwo
T245S Slide Troubleshooting
Hello All,
I have "inherited" a 2008 Komfort Trailblazer T254S travel trailer with a non-working slide out system. Unfortunately, the manual supplied from Komfort is nothing short of lackluster. I have removed the service panel on the bottom of the trailer to find the motor and a set of wire crimps, but am not getting 12v here when pressing the switch.
I also checked for 12v at the switch location, and it is not present. From what I have read and seen on several forums, there should be a fuse or relay somewhere near the battery system, which I cannot find.
I have also removed the load center to see if there are any obvious fuses or distribution blocks, but again nothing that seems to tie in to the wiring I see at the switch.
I'm at a complete loss at this point and hoping someone else out there has run into this and been able to resolve the issue. It's a real bummer that Komfort went out of business and Thor (the parent company) no longer seems to have any support contacts for the brand.
Any help would be greatly appreciated!
  • Hi Jerry,
    I've looked for said "circuit breaker" for most of the day now and have found nothing.
    I was able to find a fuse distribution panel on the underbelly near the front of the trailer, but all of the fuses are fine and everything passes continuity tests. It appears all of these connections are also for trailer wiring going to the towing vehicle.
  • There should be a circuit breaker just a few feet from the battery. They are normally reset able. Often times it is located on the inside of pass through wall.
    Jerry
