westend
Jul 30, 2014Explorer
The brochure weights will not be the on-road weights. The trailer listed has a published UVW of 2745 lbs. and a GVWR of 3850. After you add the options package, a battery, a propane bottle, and 500 lbs. of camping gear, the weight will be around 3600 lbs. The tongue load will be around 470 lbs. That's without any water or waste in the trailer. If you start the trip with 20 gals. of water in the tank, you could estimate the tongue load as an even 500 lbs.
You can use the weights above to mate to a truck of your choice.
