budwich's avatar
budwich
tandem axle brake wiring... series between front and back?
I decided to chase an issue with brakes today. In the past, the trailer "pigtail" had an issue where it was "compromised" as it passed by the battery tray such that someone (previous owner) had spiced a few wires... one of course was the brake wire (ie. blue). I had corrected this work with new splices and better weather proofing.
I noticed this spring that the brake controller had to be increased to get an "equivalent response" to previous years (year three). On the Prodigy P2, it went from 9 to about 12 now.
Previous park / storage for last month, we noticed a loss of brake light on one side. Some playing with bulbs (swap) pointed to the TV / trailer connection. Some "light cleaning" with wd40 restore the lights but gave "notion" to perhaps a dirty plug connection that needed addressing. Hence, how I got here.
The trailer is a terry dakota 20 footer ... 2006 2007 depending on what "marketing" you believe... :-)
So I start looking, thinking that perhap poor connection at the plug were to blame for all things happening now, ie. the brake "issue", lights. Measured the resistance at the trailer plug... 3.2 ohms... ? seems high. same after cleaning with small file.
look in the dexter book, says each brake is 3.2 ohms... what! (more explicit than that... :-) )
So I pull apart "surgical area" of the cable... well wrapped with tape and interior "cast" of bicyle tire tube. The area seems pretty good but get down the to crimp connectors and find the blue wire connector / crimp was loose and wires only lightly touching.... guess my attempt at a crimp was just as good as the previous owner... :-)
Get a new crimp and re-crimp things... with a better crimper than my earlier flat stamped steel one. Great, so check out the resistance at the plug. Hmmm, resistance has dropped, as expected, now to 1.6 ohm. Kind of strange that it is "exactly half" of the 3.2 / brake resistance that the book indicates for one brake wheel.
I check out the rest of the cabling where visible along with jacking the wheels off the ground and spin / brake test each wheel. All work / lock depending on voltage setting, including breakaway switch pulls / test.
Looking at the wiring at the front axle, driver side, there is one pair of wiring coming from the frame of the trailer, I assume, feed.
The pair is then mated with a pair of wires that go to the brake drum on that side along with a second pair of wires going thru the axle to the far side drum / brake... basically 3 wires at each "splice pack".
Similar wiring shows up at the second axle on the driver's side.
I haven't traced thru the wiring channels on the frame of the trailer or the wiring box yet, but based on the measurements and the fact that there are only 3 pair of wires at each axle, it would almost appear that the front and rear axle are wired in series.
Not sure is this is true yet as it will take some work to "tear into" the frame wiring which I am not sure that I want to do at this point... kind of leave well enough alone sort of thing.
My question would be... Is series wiring of the brakes on tandem axles an "option" that people (builders) can use... the brake drum wiring at the axles and drums appears to be "original" based on crimps packs used (I have never seen that kind of pack available for general public...flat pack with three wires on one side).
Any comments of this setup. I would think it lowers braking current which might be useful such that the controller has a broader "control range" to prevent such that things like grabbing / locking may be reduced possibly.
thanks for any comments / guidance.
  • we were having braking issues on our 4000lb(loaded) tandem axle tt. ohm reading was around 3 ohms, good voltage at the 7 pin.
    but the most important check of electrical performance is the current draw at maximum braking. it should be around 12-16 amps. resistances and voltages are meaningless numbers, you need to measure the current
    a decent vom that reads up to 20 amps will do the trick
    shown in the pic, I'm applying the trailer brakes from the trailer battery directly "through" the vom and the meter is reading 9 amps. this was part way into the rehab of the brake wiring, I went from 4 amps to 12.5 amps.
    I replaced every wire, from the truck battery to the controller, to the truck 7 pin, new trailer 7 pin whip, new wire down both sides of the trailer.
    I ran a new 10-3 cable down the length of the truck, used it for 12volt supply to the tt battery, brake and ground. I also ran 10-2 to the brake controller(power and brake) at the tt I used a new whip, new battery wires and new 12-2 to the brakes, one cable down each side. I did not cut the cable at the front brake, I stripped the wire enough to wrap the magnet wires around the cable then soldered and insulated everything. I used "liquid" electrical tape for decent weather proofing
  • Your OEM wiring is a daisy-chained parallel configuration. The wires are fed to one brake location and then proceed to each following location. The best remediation is to rewire the brakes in a Star configuration, a pair of wires or at least one power wire to each brake location. You can terminate the star wiring at a terminal strip in the front of the trailer and lead your umbilical wire to this terminal strip. If you install a pair of wires to each brake, and install the terminal strip, diagnosing an electrical brake problem becomes very easy. It can all be done from that forward terminal strip.
  • Only one axle connected is what I thought at first also, but couldn't be possible after reading this comment by the OP.
  • lenr's avatar
    lenr
    Explorer III
    The brake coils are wired in parallel, period. Your 1.6 ohm reading possibly indicates that only axle is connected. I have totally (every single wire replaced) rewired 2 trailers of the OP's vintage with dramatic results. Increasing the wire gauge never hurts either. I usually run 12 gauge with one wire from each axle to the connection with the 7 lead umbilical cord. If OP still has the original wire inside the axle tube it's time to replace it with new wire tie wrapped to the outside of the tube to prevent future shorts.
  • you are right... even my "series" postulation is wrong. Guess I need to dig deeper into the runs. Fun, fun. Next up, the cable box under / on the frame.
    thanks.
  • That is a strange resistance reading you got (after the re-splice) if that reading is at the trailer plug. If the 4 brakes are connected in parallel then the ohm reading should have been .8 ohms. If connected in series the reading should be 12.8 ohms. If connected in series/parallel the reading should be 3.2 ohms.
