drsteve
May 30, 2019Explorer
Your 30 amp dryer outlet has two hots and a neutral, and uses the neutral as ground. To utilize it as a 30 amp RV outlet, it needs one hot, the neutral, and a separate ground.
I would just use your 20 amp outlet with an adapter.
Wait, on edit I see that your dryer outlet is a plain 15-20 amp outlet with a 30 amp breaker? That isn't right... What size is the branch wire?
