valhalla360
May 30, 2019Navigator
Check the voltage. If there are 3 pins and it's 120v...yes, it should be fine or just keep life simple and plug into a standard household outlet.
If you are not running the Air/Con, Electric Hot Water Heater or Microwave....you are unlikely to ever draw more than 5-10amps and a standard household outlet can easily handle the load.
