cavie
May 30, 2019Explorer
jerryjay11 wrote:
Considering your gas dryer also uses 120 volts for the "gas valve" (not referred to as an element) you may need some fine tuning on electrical circuits. The 30 amp outlet for your dryer is 240 consisting of two hot, and one ground wire where as your RV uses one hot, one ground and one neutral wire for 120 volts. It would be better to add one 30 amp 120 volt CB and the proper wire to an RV outlet and much safer it would be. The RV outlet polarity must be wired correct as well.
You can google RV outlet wiring schematics and if you are not sure, well?
deleted..
