HUNTERJEFF
May 27, 2013Explorer II
Tarp to cover camper
I was wondering if anyone is using a tarp to cover their camper. I am sick of buying covers that only last a year and don't want to spent five hundred dollars for a good cover Thanks Jeff
I've used poly tarps to cover my camper, and they've worked pretty well. I usually go for a heavy-duty, UV-resistant tarp to make sure it lasts longer. The key is to secure it tightly to prevent flapping and rubbing that can cause wear. Using bungees or tie-downs helps a lot. Also, look for tarps with reinforced corners and edges for added durability. Hope this helps!
