steve_l's avatar
steve_l
TC shifted
Hi I am a first time TC owner with a question. My truck is dedicated to just hauling our Cirrus camper so it has never been off. The truck is up for state inspection and fuel and oil service but our dealer said I must remove the camper. After looking at the camper it has shifted to one side is there any thing I should be concerned with when I remove the camper? Thanks Steve
  • Sidecarflip
    You need to move the tork lift brackets to the other hole. No way they're wider than the camper unless the camper is only like 7' wide and brackets on wide setting.
    Op campers move. Just shift it back over. And if it bugs you, shim it against the wheel wells with a couple boards.
