bkenobi's avatar
bkenobi
TC sliding around in bed
I loaded my TC in Seattle and it was slightly off cener at the front (2" difference, so 1" off center). It was close at the back, but not touching either side. I didn't have time with daylight to fix it before the trip. We drove to Sacramento over the last couple days and now the camper is close to 3" at the front and touching on one side at the back. I don't have any blocking at the front and don't load it to the front.
I use a 3/4" horse mat on Rhino lining and Torklift tie down system. I haven't noticed any shifting in the past. It's possible the mat is flipped from what I normally have it so maybe one side is more slippery. I hate to reload it on the road, but it feels like I have to here.
I've seen guide systems that also lock the TC in place. I've also read that the thick mat is bad. The TC mfg recommends 1" plywood and 3/8" rubber mat so the cab-over clears correctly (it clears now, with 3/4" mat and spray liner). I am looking to make a change, so now's the decision time.
Does plywood slide on spray in bed liner? Is the thicker mat I'm using creating this issue? The cabover bounces a bit when driving but I'm not sure how much of that is expected or caused by thick mat. All suggestions are appreciated!
