mkirsch
Jan 18, 2017Nomad II
You guys missed one thing:
He wants a TELESCOPING tongue, not just an extended tongue.
I'm not sure such a thing is even legal. You'd have to check state laws on trailer construction.
For sure you'd need at least two ways to lock the tongue in position. It would be counterproductive to have a lone locking pin fall out or fail in a hard stop, sending the trailer into the rear of the camper.
For sure you'd want the slip fit to be TIGHT. You don't want it rattling around on you back there. Of course then a little bit of rust will cause the telescoping tubes to seize tight.
For sure you'd want the extension to be STOUT. Big beefy square tubing, but also be aware that with the stout come the pounds. It will definitely be heavier than a receiver extension, that's for sure.
