stevenal
Jan 27, 2017Nomad III
adamis wrote:
Adding 75lbs of metal on the tongue can easily be offset by packing some weight over the axles or slightly behind to act as a counterbalance to offset the weight.
Still not getting it. It is not the few pounds of added metal, it is the changing lever arm length. When extended, you would want to move cargo forward not back in order to keep the same tongue weight.
