adamis's avatar
adamis
Nomad II
Jan 17, 2017
Telescoping Trailer Tongue Extension Question
I currently have a 12 foot cargo trailer and I'm looking at purchasing a 26 foot travel trailer both of which will be towed by my truck with camper for business purposes (one at a time of course). I've considered having a local welding shop modify the tongues of both trailers to have a telescoping trailer tongue that can be extended / retracted depending on whether I have the camper on the truck or not. I already have a super truss hitch extension in place but I'm thinking that having the ability to extend the trailer tongue as needed will be more convenient for my use then having to add and remove the super truss. Doing a quick google search seems to be turning up a few results that look interesting.
On my Bigfoot 10.6E Camper it does extend past the bed of the truck by ~3ft but it does not drop below the height of the bed. I think I should have plenty of clearance for when the truck and trailer are at extreme angles to each other. Most of my time I'll be on pavement anyway and about the most extreme angles I'll likely encounter are driveway entrances and speed bumps.
I think I would need about 3ft of telescoping tongue to fit my needs. Does anyone have any experience with such a setup?
I found an example of someone doing this type of work here:
  • Often we see tongue extensions on a trailer behind a TC. It is much more stable than an extended reciever off the TV. Handling of the TT improves with the added length. Use stout tubing
  • Actually, it's a great idea. If done well. A few things come into play, first being you're actual tongue weight and the style of construction of the trailer.
    I'm not to excited about the way it was done/type of trailer (square tubing) of the pictures you posted
    I've done it, running one now that has a welded 18" extension. I have weighed lately shaving 24" off the truss and extending the tongue further. Would solve a couple of issues for me, but... haven't had the time as of late.
  • IMO this idea is a solution looking for a problem.
