joelynExplorerSep 15, 2017Temp. Sensor???on a 2012 ram 1500 crew cab does anyone know where the sensor should be for the temperature reading in the truck on the dash??
camp-n-familyExplorerSep 15, 2017I believe '12 and older, the temp sensor is mounted on the rad support.From '13 and newer it is located on the bottom side of the drivers side mirror arm.
Related ContentAmbient Temp Sensor TroubleshootingReplacement Battery Temp sensorBudget temp sensors (data storing)4L60E temp and sensor locationValarm temp sensor
