jabres's avatar
jabres
Explorer II
Jun 12, 2019
Terrible condensation/mold? What to use to prevent
So, I have a 2014 Keystone Hideout travel trailer. Bought brand new, was tired of used leaky trailers. I have kept inside my pole barn since day one, so never ever leaked a drop of water.
This winter, I never messed with it much, or really even went in to check on it. Just knew it was winterized, inside, and good to go. WELL, not so much. I left a few windows partially opened, and it appears I suffered from interior condensation and now surface mold in spots from over winter storage. More than just a tad bit, so really makes me mad!!
How do I control this from happening again? Rid-ex stuff? I really hate the idea to plug in a dehumidifier all winter long. Ironically the mold attached to random things like baby pack and play, skillet, and other random things that I threw out. I will be scrubbing everything else top to bottom this weekend.
Thanks in advance!
  • thanks for all the helpful advice! Heavy scrubbing begins this weekend, and real good cleaning. Hoping for the best, makes me sick as we bought this trailer brand new to eliminate any problems.
    thanks!
  • DampRid or Humidri, two buckets of DampRid worked for us with 4 months in a damp cave, but if you're going 5-6 months the storeage place recommends the Humidri which is a bit more expensive but apparently does a better job (I believe it's a pail of the silica gel beads like what you get in many packages like shoes that a transported in shipping containers)
  • We're on the west coast of BC where it rains almost non-stop for 6 months over the winter. Have a cover on our TT in the off-season and crack a couple of roof vents and windows. Have never had mold. We use damp-rid, as do most. We have a hygrometer in the TT and humidity is a bit higher than I'd like but doing better than Damp-rid means a dehumidifier which uses power and needs emptying periodically (or draining directly outside).
    The colder the outdoor temp. is, the less moisture the air will hold. Cracking a vent and/window shouldn't cause a problem. I would avoid ever heating the interior. Condensation of surfaces *might* occur, I think, if there is enough temp. change in the day like say when the sun comes out for a while then cools down quickly but if inside a barn might be unlikely. For those that camp in the winter, sealing up the interior to conserve heat is a bad idea.
    The infamous "leaky condo crisis" of the 80s & 90s was caused by inadequate ventilation and leaking building envelopes (windows, siding, etc.). For many years, there were condos & other buildings all over draped in humongous tarps while they ripped off the exteriors, drywall & insulation down to bare structure and re-did it all. The building code in Canada was changed to require continuous ventilation, usually a bathroom fan hard-wired to stay on.
    As mentioned, mold can be there and unseen. Take a food source like luan and just add water and voila... Some types are toxic. Can be difficult to eradicate sometimes, depending on type. Bleach will work in some cases, but not all. In the worst of cases, some homes can't be salvaged. If it's bad enough, the only way to eradicate it could involve pulling off the luan walls & ceilings.
    I would get a hydrometer and see what the actual RH is. Maybe talk to a mold professional. Also check with your insurance co., if insured over the winter to see if covered.
