Groover
Dec 14, 2021Explorer II
Getting run down EV's going shouldn't be a big problem with a little preparation. All you need is to have a small generator or portable battery pack to get the electronics awake in the event that the batteries are totally run down. In the few minutes that it takes to get them up rig install the towing eye and lash the EV to a tow truck or other handy vehicle with adequate charge/fuel and tow it away. If the towing vehicle has enough extra towing juice use regen to in the stranded EV to quickly charge it up enough to make it independent.
While it is not recommended I have seen several tests where people did just that and it worked well.
