crawfdp1's avatar
crawfdp1
That annoying parking assist alarm...
My new truck came with ultrasonic backup parking assist, and the "collision" alarm sounds when the camper is mounted and I shift to reverse. Not a new problem, saw complaints on a forum somewhere last year but just smiled as it didn't apply...
Got *real* tired of the noise-- no way to turn off sensors other than once per key cycle. So, I made some sensor caps from 3/8 PVC trim board, a PVC vent cap, and some rare earth magnets. Got lots of bumper space on my F350 dually-- these are 3.5 inches OD. All the plastic is solvent welded, mags are a press fit to flush with T-88 epoxy underneath. Inner ring is a snug fit over the sensor so there's no sliding on bumps. Central foam is a piece of 3/4 packing foam. Foam plus compliant cap absorb the ultrasonic-- no more noise when I shift to reverse. They work nicely around town, not yet tested on long road trip, but a strip of Gorilla tape is Plan B to ensure they don't go missing. Made two spares just in case.
Pic up on Dropbox here: https://dl.dropboxusercontent.com/u/80200697/Backup%20sensor%20caps.jpg
duncan
  • No truck camper, but as long as I have my trailer hitch in the receiver, my systems indicates it's disabled. Perhaps you could just get a hitch shank and insert into the receiver. I don't know why it disables mine, but it does.
  • There is another way to "turn off" the back-up sensors. The idea is to fool the computer into thinking you are pulling a trailer in which case it deactivates the back-up alarm. One way to do that is to buy a 7 pin tester, one that mimics having trailer brakes. For example:
    7 pin trailer simulated
    If you leave it plugged in your sensors will not come on.
