wilber1
Jan 03, 2019Explorer
Samsonsworld wrote:
Shift speed doesn't matter. The gears aren't what slips. The torque converter acts like a clutch. If you've ever been in a vehicle with a shift kit, you'll understand. No slip = very hard shift.
ZF 8 spd
All sequential upshifts and downshifts with this design involve just releasing one shift element and engaging another. In engineering literature, this is referred to as a “clutch to clutch” shift. Many skip shifts are also possible in the same way, e.g. a shift from Eighth to Fourth involves releasing brake A and engaging brake B while leaving clutches D and E engaged. This transmission therefore shifts very quickly. If the torque converter is replaced by a launch clutch, this transmission would be equivalent to a dual clutch transmission.
44,068 PostsLatest Activity: Jun 21, 2026
