ShinerBock
Jan 05, 2019Explorer
wilber1 wrote:ShinerBock wrote:wilber1 wrote:
If any clutches slip under high power, they will be toast in a short time.
True, and as I stated above this kind of slippage will not happen any time soon, but it will eventually happen. However, the slippage during constant shifts(which happens a lot when towing) and other things I stated above will cause the fluid temps to rise and decrease clutch life.
According to the comments section in the article I linked, the solenoids usually give up before the friction surfaces.
A normally aspirated engine with a narrow torque curve can be expected to do more shifting than a boosted engine with a fat torque curve. The transmission temperature probably has more to do with the engines than the transmissions.
I don't pay attention to the comments section of articles because you don't know the experience and knowledge of the person making them. Do they actually have experience or are they going of what someone else has stated? Also, are they referring to cars when they state that the solenoids go out before the clutches or is with heavy trucks towing thousands of pounds like we are discussing here? There will be a huge difference in shift slippage and clutch wear between the two.
Either way, it is neither here nor there because as we have seen in the video I posted, the ZF 8 speed can and does get hot when towing due to the reasons I stated earlier. One of them being due to slippage during constant shifts and trying to move more weight while towing. If that XF in the link I posted got up to 203F towing just 7k in the cold, I am sure it will get much hotter towing close to max (@ 11k) in the heat of summer.
44,068 PostsLatest Activity: Jun 21, 2026
