Bedlam
May 13, 2018Moderator
You will need frame mounted tie down points and possibly some suspension help for any truck you purchase (unless it already set up for a truck camper). This will cut into the time you buy a truck and get these items installed. The GM trucks are the most comfortable but rated for lowest payload. The Ram trucks are typically less expensive than Ford or GM and have a good payload. Unless you are towing a heavy trailer, you do not need a diesel truck. You may find a gasoline engine powered truck for a better price that is in better or newer shape.
44,060 PostsLatest Activity: Mar 28, 2026
