ktmrfs
Mar 25, 2017Explorer III
FishOnOne wrote:06Fargo wrote:
The altitude should not matter with turbocharged/intercooled engines.
It could be the special transmission programming, explained here:
Clicky
It does matter... Less oxygen in the air means less power. If you noticed on the video they even input a fudge factor due to the altitude/less oxygen.
very very true. doesn't make as big a difference as it does with a normally aspirated engine, but altitude still has an effect. Dyno numbers need to be corrected to STP (standard temperature and pressure) and for humidity. and it WILL affect real world performance as altitude increases.
