- HuntindogExplorer
ShinerBock wrote:
Huntindog wrote:
ShinerBock wrote:
Especially those that think they "know" how a dyno works and cry foul because their favorite wasn't the best.
I can see that you are smarting over your "Fords lack of a cold air intake" theory being questioned/debunked, by the Ford/Ram 30K Ike test results being inconsistent with the other test.
What else do you KNOW?:B
On the contrary, I don't see it being debunked in an form or fashion and the only one that questioned it doesn't have an answer himself so......
I also KNOW quiet a bit actually. Like how dynos work and how it is very hard for them to be inconsistent from one vehicle to the next unless there was an issue with the vehicle itself. I KNOW that some people think dyno runs from other dynomometers ran on different days and at different altitudes are valid dynos to compare to this one when that is far from a valid comparison. I KNOW the guys at ATS know what they are doing and have ran dynos for many diesel competitions and review sites including Truck Trend, Diesel Power, Pickuptruck.com, and many more. I KNOW that not one of the three the Duramax runs shown at 8:57 of the video broke 772 lb-ft.
If you want to play this game, I'll be your huckleberry.
There is really only one realistic possible explanation for the Ike 30K results being inconsistent with the other test result.
But you cannot consider it, let alone accept it.
You "KNOW" too much - ktmrfsExplorer IIwell, after 7 pages. My 2015 duramax does just fine pulling the trailer I have, at 18,000lbs combined GVW up any hills I want at any speed I want. I'm sure the ford and dodge will do the same.
All of them have more than enough power for towing most anything. - ShinerBockExplorer
If you want to play this game, I'll be your huckleberry. - Me_AgainExplorer IIIOnly an immature person would be concerned about the difference in performance in this dyno test or the mountain pull tests. They all do very well, people need to get a life and go camping or snowbirding or maybe grow up!
- HuntindogExplorer
What else do you KNOW?:B - boshogExplorerLook at the bright side, it gives you all something to needlessly argue about and for people like me, good entertainment, especially after spending 12 years at GM Powertrain in the premium V8 and diesel group. :)
- ShinerBockExplorerEspecially those that think they "know" how a dyno works and cry foul because their favorite wasn't the best.
- HuntindogExplorerWell it seems that we have three different tests with results that are inconsistent with one another...
Of course there are plenty of internet experts that "know" why that is...
But I think it is all good campfire BS...
Everyone has a THEORY.... And that is all it is at this point. - larry_barnhartExplorer
FishOnOne wrote:
blofgren wrote:
FishOnOne wrote:
blofgren wrote:
ShinerBock wrote:
4x4ord wrote:
Here's a theory. All three trucks ran up the hill in about the same time, therefore they were all three putting about the same power to the ground during the run. The Duramax likely ran up in a lower gear than the other two trucks and likely revved a little higher. If the trucks were making the power that the manufacturers claim the Ram would have been significantly behind the other two. I believe the more refined engines, the new Duramax and Powerstroke were not making the kind of power they should have because the computers were slightly limiting the max fuel delivery on account of the high altitude....lower oxygen. Maybe in order to keep emission levels in check? Obviously if more fuel would have been injected in any of those engines they would have performed better. I would really have liked to see the outgoing Duramax involved in the challenge.
I agree with you as to why the GM won over the Ram. It was in a lower gear at higher rpm making a lot more power. Although it should have been more than just fifteen seconds ahead with its rated power numbers. With traffic, 15 seconds is basically equal time in my book.
The performance of the Ford in the test is more of a head scratcher and I am still thinking it was computer programmed defueling due to high exhaust gas temps. Adding power(more fuel) to any diesel increase EGT's very quickly. With my brother's 450whp(estimated 515hp at the crank) custom tune on his 2012 F350, he can get to 1,200°F EGT's in a matter of seconds at WOT. What decreases EGT's is lower intake temps and a free flowing exhaust. There is not much the manufacturers can do about exhaust back pressure due to the emissions regulations, but they can do something about the intake temps.
Currently Ford is only one without a front air intake which greatly reduces intake temps. GM has it's hood scoop and Ram has it's active air through the grille. IIRC, I wanna say that for every 1°F you lower your intake temp then you lower EGT's by 10-20°F, but I cannot remember the correct numbers. The Ford is also the only one of the three that has a liquid cooled intercooler which are good and efficient with normal driving or towing, but they get heat soaked under long periods of load like the Ike tests. If that intercooler got heat soaked, then the Ford's EGT's would have skyrocketed requiring the ECM to defuel to cool them down on top of already having less power due to hot incoming air.
This actually makes a lot of sense. It's surprising that Ford hasn't addressed the intake air issue, though.
The Ford pulling 30k lbs up the Ike didn't have a intake air issue and I believe it outperformed the ram with similar fuel economy.
OK so what is the explanation for these results?
I don't know...
Well it seems a lot of you guys know than ya know???
I don't know...
44,026 PostsLatest Activity: Jan 26, 2024
