- campingkenExplorerWOW!! Our 2003 Dodge 3500 diesel has a mere 235 HP and 460 pounds of torque.
- bguyExplorerThe road sure is a nice dyno.
I'd like to see them 3 abreast from standing start. Hold it wide open. First one to the tunnel wins. Keep all the rest of the traffic off the road - 45RicochetExplorer
jerem0621 wrote:
Here is the TFL video
The results are...
Thanks!
Jeremiah
LOL
Dang that Allison sure does eat up available torque. - Cummins12V98Explorer IIIMine shifts exactly at 3K full throttle.
- Rich1961Explorer
Wild Card wrote:
RCMAN46 wrote:
Wild Card wrote:
No brainer that the inline engine produces more torque. Hp is derived by the RPM the engines can spin to...again no brainer that the V engines spin faster thus produce more HP.
Lets take a look at the spes.
Ram 6.7 385 hp @ 2800 rpm
900 ft/lbs @ 1700 rpm
Ford 6.7 440 hp @ 2800 rpm
925 ft/lbs @ 1800 rpm
Duramax 445 hp @2800 rpm
910 ft/lbs @1600 rpm.
Again... Horse Power is a calculation.
Torque in ft# X RPM /5252, thats it...this is the only way to calculate Horsepower
I also dont buy those numbers above. The V8 diesels red line almost 1k RPM above the I6. Do the math yourself.
The V8 Diesels redlining almost 1k rpm higher simply isn't true. Besides the truck in my signature which shifts at 3000 rpms under full throttle, I drive a 2011 F350 with the PSD and it shifts at 2900 rpms at full throttle. The Cummins is right at those rpms also at full throttle. The V8 diesels will rev higher than the Cummins under exhaust brake usage which is the only area where they rev higher.
Rich - RCMAN46Explorer
ShinerBock wrote:
Dynos measure torque and calculate horsepower based on the torque reading at a certain rpm.Super Chevy wrote:
"What dynos actually measure is torque, not horsepower," explains Roberts. "Since horsepower is a mathematical equation, the dyno measures torque then calculates horsepower."
Learn About Dyno Testing - How Dynos Work
This is a quote from Wikipedia on how an inertia dyno works.
Inertia Sweep: an inertia dyno system provides a fixed inertial mass flywheel and computes the power required to accelerate the flywheel (the load) from the starting to the ending RPM. The actual rotational mass of the engine (or engine and vehicle in the case of a chassis dyno) is not known, and the variability of even the mass of the tires will skew the power results. The inertia value of the flywheel is "fixed", so low-power engines are under load for a much longer time and internal engine temperatures are usually too high by the end of the test, skewing optimal "dyno" tuning settings away from the optimal tuning settings of the outside world. Conversely, high powered engines commonly complete a "4th gear sweep" test in less than 10 seconds, which is not a reliable load condition,citation needed, as compared to operation in the real world. By not providing enough time under load, internal combustion chamber temperatures are unrealistically low and power readings - especially past the power peak - are skewed to the low side. - RedwoodcamperExplorerPlus ATS has no reason fake dyno readings. They sell parts for all three. Every truck is gonna make slightly different power levels. It is funny how the oldest, most reliable and easiest to work on engine makes more torque than the much more complicated, "all new" engines.
My local phone and power companies all switched from Ford to ram in the last few years. Better value. - FlashmanExplorer II
jerem0621 wrote:
goducks10 wrote:
Fake news.
it's not fake news.
These TFL guys are a little corney but they do a much better job than some of the automotive journalist and get much closer to real world use with the limited time they have these trucks.
* Hitch up a trailer and drive it up a mountain.... see how long it takes...how does the truck handle
* Hitch up a trailer and drive 100 miles and check the MPG
* How much actual power do these things make? IDK, let's hook it up to a Dyno and see
I enjoy these videos much better than anything motor trend and the like produce. Heck, while everyone was fawning over the Ridgeline it was TFL Truck that proved that you can overheat the transmission in a Ridgeline just taking it moderately off road on a real trail. Nobody else reported that sort of thing.
Geeze you could give some folks a pot of gold and they would complain about the size of the pot.
Thanks!
Jeremiah
Well said
The complainers are probably from the fan club of the brand that did not do too well. - ShinerBockExplorerDynos measure torque and calculate horsepower based on the torque reading at a certain rpm.
Learn About Dyno Testing - How Dynos Work - jerem0621Explorer II
goducks10 wrote:
Fake news.
it's not fake news.
Thanks!
Jeremiah
44,050 PostsLatest Activity: Sep 08, 2025
