FishOnOne
Feb 20, 2020Nomad
Cummins12V98 wrote:
"The Reality is the 2020 Power Stroke had significant better fuel economy than the 2020 Duramax pulling 30k up the Ike so I don't get your reality statement unless you have mpg data from each brand to back it up."
Sorry but I hope you don't wager any $ on this so called test. As mentioned too many variables filling the tanks.
Even if so it's still not enough of a reason to pick the Ford, now let's add the good towing mirrors and the tight turning radius of the 450. UH, nope still not enough to make a buying decision. ;)
I’m not here to sell trucks, hitches, tires, etc.
Bottom line the Ford made better fuel mileage than the GM pulling 30k lbs on what appears to be a flat road using hand calculated method by which most people accept as a acceptable method.
44,066 PostsLatest Activity: Apr 16, 2026
