mountainkowboy
Sep 01, 2011Explorer
Got the tin painted and installed under the C/O today, along with the pass-thru window sealed and mounted. I didnt do anything with the tin that rolls under the front since it has a wear through hole in it and is torn in some places. In a week or so that will be replaced with 1/16" aluminum diamond plate, along with the lower front section under the pass-thru window. Tomorrow I will drill and glue dowels into the front jack bracket mounting holes cause some of them are stripped from over torquing them. I am also painting the the jack brackets and dually swing outs to match. The wife has started making the new curtains for the inside also.
If you notice the black at the bottom of the front.....thats rubberized undercoating. It sticks to wood, or anything else for that matter, and is paintable. I found it at Checker Auto Parts, on sale for $1.78 a can. Should last forever.
It's getting there, should be ready to camp by the end of the month.
44,071 PostsLatest Activity: Aug 08, 2026
