mountainkowboy
Sep 03, 2011Explorer
Camper_Jeff_&_Kelli wrote:
Where are your Gray and Black tanks located? I have a 9.5 S&S and they aren't in the same spot.
It's interesting to see the framing of your camper as it tells me possibly mostly what I've got.
Been a great post to follow. Thanks for all the great information you've generated.
J&K
If you look at the pic of the pass side you can see the black tank on the right with the hose flush connection. It's about the size of the shower pan and sits right under it. If you look a little to the left you can see the dump valve. Behind it in the basement is the grey tank, and it goes all the way to the front. Over one more tick to the left is my fresh water drain, that is routed to the underside of the unit. Doing a large repair like I have been doing, gives me an understanding of how well these units are built. This is the first time that access doors and things have been removed from this unit and the PO was not very vigilant about maint., I got it for a good price and thought that I would find some rot, but considering the condition of it when I got it, I'm pretty happy
Wait for part II......that will be the interior redo!
44,071 PostsLatest Activity: Aug 08, 2026
