ShinerBock wrote:
goducks10 wrote:
ShinerBock wrote:
goducks10 wrote:
How about I put it this way. I tow a 9500# TT. For my lifestyle I don't need a diesel anymore. My truck sits for weeks at a time. I would like about 50 more HP and 75 lbs more of TQ. That would be about perfect for my camping style. What I don't need to do is spend $10,495 for a diesel that's overkill for my situation.
I think you're missing the point of gas owners. Maybe I'm wrong but my guess is that most just want a decent amount of an HP/TQ increase and don't need the massive power output of a diesel at the cost of the option when it's not something thats being used enough to validate.
Why do one have to "need" the power of a diesel in their justification for it, but would turn around and buy a more powerful and expensive gas engine even though the base gas engine will do just fine? You don't need a 7.3L or an addition 50 hp or 754 lb-ft to pull a 9,500 lb trailer. Heck, you don't even need an SD to do that. But I bet you want it just like you want more power. No need to justify things by saying you don't need it if you end up buying something you don't need in the first place. You don't need a 9,500 lb RV, but I bet you spent more than what a diesel upgrade costs because you wanted one.
I just don't get why needs and recouping your money always comes up when talking about a diesel engine upgrade, but never does when talking about a gas engine upgrade.
How do you know what I need or don't need?
So a half ton F150 will not pull your 9,500 trailer? If not, wouldn't a 6.2L SD? If so, then you don't need the power of a 7.3L. However, you would spend the money to get one because you want one just like most diesel engine owners do.
My TW is 1350+ lbs. So no a 1/2 ton won't tow my trailer. I also load quite a bit in my trucks bed so I want a CC LB. There are no CC LB 1/2 tons. Thats why I own a 3/4 ton truck.
I also bought the 6.4 because in 2018 when I bought it the 5.7 2500 only had 2100 lbs of CCC and a 9000 lb GVWR. I knew I was getting a different trailer and was on the fence about staying with a 5er or going back to a TT. I didn't want to max out the 5.7's 2100 lb CCC with a 5er.
2nd, I've never stated anything about recouping costs from owning a diesel. In fact I've always been one to say that for many buying a diesel is no different that someone buying a truck with leather, nav, and a moon roof. No one hopes to recoup the costs of those options. They buy then because they want them.
And I never said I needed more power, I said I would 'LIKE' more power. Who wouldn't regardless of what they own. Just because I don't need it doesn't mean I wouldn't like it.
