- cross21114Explorer
SidecarFlip wrote:
Biggest load I ever pulled was 240,000 pounds on the deck, 6 40K steel coils, all in a row.
I thought you could only get an overweight permit for a load which could not be separated? Seems your load could have been 6 individual truckloads. - RobertRyanExplorer
wq93 wrote:
Maybe the driver would be happier in the Australian outback running a road train:
Australian road train
We have a lot of B Double and now B Triples as they are called here are limited to 120 Tonne(264000lbs) - SidecarFlipExplorer III
Z-Peller wrote:
Only a Cat 3406???....buddy back in the 80's had a Freightliner cabover with a "Cat 3408/ 18 speed RoadRanger" in it pulling 140'000lbs A-train beer wagons thru BC mountains. If that thing stopped on a hill tires would chirp & bounce and start folding up asphalt getting going again.
3408's and 1693's were obsolete 40 years ago. You cannot even get parts today. Hard enough getting 3406 parts in as much as Cat quit producing the engine family after the Tier 4 debacle.
Usually, rolling up asphalt results in a twisted driveshaft. - RobertRyanExplorer
SidecarFlip wrote:
RobertRyan wrote:
SidecarFlip wrote:
lets see, was grossing 165 thousand and change. No big deal. For years I ran down the road grossing 163 and change legally (and sometimes a bit more (not legally).
All with Cats, Cummins don't come close to the pulling power.
Was on an 11 axle unit, 3 on the tractor, 8 on the trailer. 4 lift axles for turning, 2 in the front and 2 in the back. Always a 3406 with either a 13 speed or an 18 speed Roadranger.
Thats everyday up here in Michigan, parts of Ohio and Indiana.
Latest European Volvo has a 350ton capacity straight from the factory
Too bad Volvo's are butt ugly. I'm a Western Star convention person, aka: hood. Vo-Mack is also difficult to work on.
It is the European Volvo not the US Volvo. A 750hp 16litre Diesel . Western Star are now owned by Mercedes - wq93ExplorerMaybe the driver would be happier in the Australian outback running a road train:
Australian road train - Z-PellerExplorerOnly a Cat 3406???....buddy back in the 80's had a Freightliner cabover with a "Cat 3408/ 18 speed RoadRanger" in it pulling 140'000lbs A-train beer wagons thru BC mountains. If that thing stopped on a hill tires would chirp & bounce and start folding up asphalt getting going again.
- BoatycallExplorer
SidecarFlip wrote:
towpro wrote:
must have had a Cummins in it.
Probably a Cat of the 3406 variety. Might have had a Cummins for a starter motor....:S - SidecarFlipExplorer III
Too bad Volvo's are butt ugly. I'm a Western Star convention person, aka: hood. Vo-Mack is also difficult to work on. - RobertRyanExplorer
Latest European Volvo has a 350ton capacity straight from the factory - RedwoodcamperExplorerThat's like seeing a one ton light duty truck hauling a 45-55k lb trailer. Sketchy. I'm not a member of the weight police at all, but I wouldn't want to be on the road near that truck.
44,052 PostsLatest Activity: Oct 09, 2025
