Tizi's avatar
Tizi
Thinking About Solar
I have been thinking about adding 200-320 watts of solar to my Northern Lite. I currently have 2 group 27 12 volt batteries that I will likely upgrade to 6 volts and add 2 batteries (I am thinking about housing them in the rear compartment where the generator typically would go (there are genny wires in the compartment as well). I upgraded my converter/charger awhile back so I am in good shape there. I have been looking at package deals from Bestconverter, Amazon, and other places. I would like to attach the panels to something that is attached to my roof rack somehow (has anybody done this?). Or using 3M tape. While I am installing the solar, I want to install a 1500-2000 watt pure sine wave inverter.
Bestconverter Option
Inverter
  • 2oldman wrote:
    Then don't buy that one. It's modified, and a cheap one at that. Don't be sucked in by price alone.
    good point! bestconverter has good ones.
    Xantrex
    Samlex
    I will be running lights, fridge, space heater (500 watt), TV, stereo, water pump, etc. Might add a microwave at some point.
  • I suspect you'd have to run larger wires to the batteries in the storage compartment, they are likely 4awg which is too small for a large inverter.
  • The Best Converter solar kit looks like a reasonably good one. Just be aware that their hype is a little over done. Two 150W panels doesn't quite add up to 320W and I don't know where you are going to get "6-7 hours of optimal sun" without a tracking system. Plan on 4-5 hours and you won't be disappointed.
    That inverter is a "modified sine wave" unit (i.e. square wave) and may not work with a microwave or other electronic gadgets. I would recommend a true sine wave inverter. It will cost a bit more but will work for anything you might plug into it.
    We mounted an AM Solar kit on my sister's van conversion a couple of years ago. It used the 3M tape and is holding up just fine. If you clean the surfaces well with alcohol that tape will never let go. It is used to hold the aluminum skin on busses and horse trailers, among other things. Good stuff.
  • I believe sleepy attached his panels to a roof rack. I'm sure someone else has as well. The converter/charger has nothing to do with the solar charging. At least, you shouldn't go through it. I'd definitely not put the batteries in the generator compartment. that's a lot of weight in the wrong place. I'd mount them in the bed instead and use an Andersen connector.
    I don't know if those are good panels or not. There have been a lot of threads that give the basics on what to look for. I'm sure someone else will chime in.
    What are you planning on running off the inverter?
