JimK-NY
Apr 04, 2020Explorer II
I tried to find a suitable bottle jack for my camper and quickly ran into two issues. First I needed completely different initial height and throw specs for the front and back of my truck. You need to make sure that when a tire is flat, there is sufficient space under the lifting point to fit the jack. A second issue was the lack of a cradle on most bottle jacks. For the rear of the truck, I needed to lift on the axle. I needed a cradle to securely hold the axle. Eventually I found a floor jack for home use but it is too big to try to carry if I needed it during a trip. You should be able to get by with the OEM jack. Just undo the tiedowns and use the camper jacks in conjunction with the OEM jack.
Ten years ago I bought a relatively small Slime compressor from Walmart for about $40. The current cost would probably be about $50-60. It has lasted and I use it frequently to keep my tires at max pressure. I was also able to use it to pump up new, semi-flat 19.5" tires to 105 psi. That was slow and reflected what would be needed to pump a flat tire. I had to run the compressor about 10 minutes. Then I let it cool for a few minutes and it took another 5 minutes or so to finish. That nuisance is worth it to me in order to keep the size and cost of the unit low.
44,066 PostsLatest Activity: Oct 04, 2013
