wa8yxm wrote:
Since my RV's hydraulics do not work properly, in fact one jack is missing entierly, That is how I level.. HOWEVER.. A suggestion.
I have found the bottle jacks tend to "Leak" a bit (internally, not externally) so they do not hold well, Oh for short periods (Like changing a tire) they are OK, but for long periods (Days of camping) they will not hold.
So, I pump 'em up past level, then lower 'em down onto a set of nice jack stands.. My stands are six ton (rear) and 2 ton (Front) which is overkill (though I( need the SIZE of the six ton jobs on the rear) all sitting on lumber to give 'em a better (bigger)"Footprint" but they do not "leak" being as there is nothign to leak.. Nice Soild Mechnical latch
Also the stands cost less than 4 Jacks would
See precautions above regarding making sure you jack on the frame. Stand under it too (jack stand that is)
Do bear in mind that most jack stands (and, for that matter, most ramps for oil changes) are rated per pair. Each jack stand in a "6 ton" jack stand set is rated to support 3 tons on its own.
