bobndot
May 08, 2013Explorer III
There are a few different slide systems out there . If i were plopping down $30k on a tc or any rv with a slide thats going in/out, in/out over and over again, i would learn how to repair it and learn the different systems and how they operate. This is going to be a major component on your tc. I would also be interested how the Mfg. supports the surrounding walls (frame) of the slide. There is no room on top for any kind of header in most brands.
Im not sure what the Lance uses,but Palomino uses a Lippert system.
Its a deep slide and must be opened up some to gain access to the bath. A bath with a pocket door rather than a hindged door might be easier to use while on the road making pit stops.
http://www.lci1.com/OwnersManuals/Slideout/Electric%20Slideout-Web.pdf
Some have had problems with this system, i would search info. regarding other system and compare.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/20724119/print/true.cfm
