- ShinerBockExplorer
4x4ord wrote:
Shiner I know you know some things. I also know you have more experience with tuned engines than I have, but when you say things like:ShinerBock wrote:
I tow mine in level 3 of 4 which is about 475 hp at the wheels. I never have a problem with EGTs, but my intake and intercooler is not stock. Neither is my turbo, exhaust manifold, and the rest of the 5" exhaust.
One can reliably tow on higher power level tunes if they have the mods to support it.
it comes across to me as though you are claiming that you can reliably put 475 HP to the pavement with a tuner plus a few mods to your intake and exhaust.... maybe you can for a 20 second run. Maybe you and I both know that, but you don't say it. You don't say that if you actually made your engine deliver 475 HP to the rear wheels the engine would overheat in a matter of minutes; You don't remind whoever is reading this that the 68rfe is designed to handle 300 rear wheel horsepower and that it will have a very limited life if it is expected to handle 475 HP. Whether the Cummins engine can tolerate that kind of power for any length of time or not I don't know but I suspect that if Ram ever wants to increases their power ratings to the 548 crankshaft HP you talk about, Cummins will make some significant changes to their 6.7 and not just because of the emission BS. I actually started out wanting to ask you some questions to learn what is out there in the aftermarket diesel world .... especially in the area of cooling.
Again, you are not reading what I am posting. I already stated that while I mainly tow in the 475 hp tune, but moslty for the power/torque it makes at 1,800 rpm. I rarely use all 475 hp except for a few passing scenarios which I stated earlier as well. Why are you not reading what I am saying? If you did, then it would have saved both of us lots of time.
I also have a custom built 68RFE which I have mentioned multiple times in other threads. Although with trans tuning and light mods, the 68rfe can handle up to around 500 hp with a long life. It wasn't until around 2013 that the tuners were finally able to tune the 68RFE to be able to handle the added power. Before this tuning, about 450 hp was all it would handle.
Beginners will generally refer to their tunes as tow, economy, race, or hot which is not really a good indication to know what kind of power you are talking about. Why? Because using terms like tow or level one could mean two different power outputs between various tuners. One tuners tow or level one on a Cummins could be 430 hp while another's could be 390 hp. Using hp increases is not a good term either because some tuners use higher gains throughout the whole rev range while others use the gains at peak.
This is why Calibrated Power Solutions(and myself) refer to tunes by the horsepower ratings in the video I posted because people will know that max effort on all of the big three current diesels tuned on stock fuel and air is about 520ish hp and giving a power level instead of a tune number or name(which could mean anything) is a way to better understand how close to max effort the tune is given what kind of mods are on the truck. Also in that video they reiterated what I have been saying about having gauges and knowing your truck before going to the higher powered tunes.
So I am sorry for you that you don't like the fact that I refer to my "level 3" tune as my 475 hp tune, but that is what it is based on my dyno and is what I will continue to call it. And I have to call BS on the learning thing. A few passive aggressive fanboy posts blows that excuse out of the water. How dare I say that the mighty Powerstroke's 475 hp rating is not sustained or say that my truck makes more power than that. You must defend Ford's honor..... lol - 4x4ordExplorer IIIShiner I know you know some things. I also know you have more experience with tuned engines than I have, but when you say things like:
it comes across to me as though you are claiming that you can reliably put 475 HP to the pavement with a tuner plus a few mods to your intake and exhaust.... maybe you can for a 20 second run. Maybe you and I both know that, but you don't say it. You don't say that if you actually made your engine deliver 475 HP to the rear wheels the engine would overheat in a matter of minutes; You don't remind whoever is reading this that the 68rfe is designed to handle 300 rear wheel horsepower and that it will have a very limited life if it is expected to handle 475 HP. Whether the Cummins engine can tolerate that kind of power for any length of time or not I don't know but I suspect that if Ram ever wants to increases their power ratings to the 548 crankshaft HP you talk about, Cummins will make some significant changes to their 6.7 and not just because of the emission BS. I actually started out wanting to ask you some questions to learn what is out there in the aftermarket diesel world .... especially in the area of cooling. - kellemExplorerI've towed with a performance tune for years without issue but posses common sense.
My only complaint is the requirement of higher octane fuel but understand why with timing advance and slower burn.
Yes, watch my guages. - ShinerBockExplorer
4x4ord wrote:
I have been reading what you posted. You didn’t seem to appreciate my post suggesting the need to watch your gauges closely when towing with a tuned truck. I just wondered what would happen if you ignored them. Seems like we agree that tuning a truck puts it in a category where you need to be careful with it while towing. I also agree with you that your turbo upgrade is a very important addition if you’re wanting to tow with a tuned truck. You come across as though you don’t think the cooling system on a stock Ram is a very limiting factor when you start adding power. I know first hand the kind of cooling that is required to put 400 hp to the pavement with a truck.... and I know you’re not going to get that kind of cooling out of a 27 x 22 inch radiator. Getting rid of the EGR is not what it used to be. Basically you can’t throw a turbo and tuner on a pick up and turn it into a Freightliner.
Again, have you even been reading my posts? Seriously, go back and real all of them and you will notice me telling people that they need gauges and supporting mods when they are towing heavy on high power level tunes. This isn't my first rodeo and I know what my truck is capable of along with what it's limits are. I am not sure why you feel the need to explain things to me like I don't.
So please, stop being so concerned for what gear I tow in and and what power levels I choose to do it in. Besides, I probably have way more experience behind tuned vehicles and various medium/heavy duty diesel engines(both driving them and test cell dyno testing) than you do so why would I listen to an armchair quarterback with less experience especially one that doesn't have any experience driving what I do? - 4x4ordExplorer IIII have been reading what you posted. You didn’t seem to appreciate my post suggesting the need to watch your gauges closely when towing with a tuned truck. I just wondered what would happen if you ignored them. Seems like we agree that tuning a truck puts it in a category where you need to be careful with it while towing. I also agree with you that your turbo upgrade is a very important addition if you’re wanting to tow with a tuned truck. You come across as though you don’t think the cooling system on a stock Ram is a very limiting factor when you start adding power. I know first hand the kind of cooling that is required to put 400 hp to the pavement with a truck.... and I know you’re not going to get that kind of cooling out of a 27 x 22 inch radiator. Getting rid of the EGR is not what it used to be. Basically you can’t throw a turbo and tuner on a pick up and turn it into a Freightliner.
4x4ord wrote:
^^^I bet if you were to ever climb a long 6 or 7% grade at 60 mph, on a hot day with that 4020 you'd watch your gauges very close. In a situation like that, would you have to back off to prevent overheating or would your programmer defuel for you?
If my temps were getting hot then I would defuel myself while my father-in-laws stock F350 will do it on its own. There are limiter built into my tuning files that, but I back it down before they are reached. Although I am not sure what the point is here since I have already stated that the various power levels I use are based on the load and temps I am at just like the stock engines. Are you not reading what I am posting? I would also ask what is the point putting my truck in a scenario it will likely never be in because I would have went with a different truck set up (like a 4.10 DRW HO) if that were the case?
The main difference is that I can sustain higher power levels than stock since I have mods that can support higher power levels and reduce how much heat the cooling system has to shed versus stock. My coolant system does not have to keep an EGR cooler and turbo actuator cool on top of keeping the engine cool. My intake is set up in a way to keep temps 10% lower than stock, and there hardly any resistance pressure in my 5" exhaust. This is essentially the same setup that my hot shot friends use on the DRW HO's that allows them to keep it at 425 hp at the wheels towing much heavier weights than I am on a regular basis. - 4x4ordExplorer III^^^I bet if you were to ever climb a long 6 or 7% grade at 60 mph, on a hot day with that 4020 you'd watch your gauges very close. In a situation like that, would you have to back off to prevent overheating or would your programmer defuel for you?
- ShinerBockExplorerI actually have towed more than what my 3.42 standard output Cummins truck was designed for on multiple occasions when transferring our cabbed John Deere 4020 tractor between properties about once or twice a year for the past five years because my father-in-laws F350 6.0 was not up to the task. Now that he has his 2019 F350 3.55, he tows it, but requires a lower gear at a higher rpm than my truck to do so.
- Grit_dogNavigator III
4x4ord wrote:
I was able to find the dimensions of the radiator used on the 2013 - 2018 Ram. It has a surface area of 588 square inches. For comparison the rad used on a 2008 - 2016 Peterbilt class 8 has a surface area of 1672 square inches. It seems to me that a person better be watching his gauges very closely if he’s going to tow with a tuned truck. Years ago I added power to a Duramax and destroyed the transmission towing with it.
I can't tell which side of the discussion you are on! - Grit_dogNavigator IIIYa know, 4x4ord, you seem like a really cool guy, but the constant, insistent antagonism is, well, not a great trait.
Like the guys on another forum who recently have absolutely insisted that a dually is no more difficult to to drive in the city, when another member was contemplating going up to a dually for occasional heavy towing but as a daily city driver vehicle.
What transpired was all the antagonists were truck drivers and because "they" could drive a "long nose Pete" through downtown....wherever....with a 53' trailer, everyone else who was whining about a "little dually" was an idiot who couldn't drive and shouldn't be allowed on the road....
The internet is a great social experiment that many can learn good or bad personal behaviors from.
44,054 PostsLatest Activity: Dec 15, 2025
