troubledwaters
Jul 26, 2019Nomad
You have to run a wire from where the light is to where you want the switch to be. Get a switch and a box (if necessary) and mount the switch in the wall. Connect up the wires properly and your done. Easier said then done. The hard part is running the wire between the two and mounting the switch (if you are at all concerned about aesthetics), connecting the wires is a 10 minute job.
