Perrysburg_Dodg
Dec 21, 2014Explorer
Well I had a 2004 2500 Ram Cummins that really needed nothing, had kept up on maintenance (more than needed truth be told) but I just could not see using a HD truck made for towing and work to drive back and forth to work.
If you have not done anything to the truck, trans service, antifreeze, brake fluid and gear lube changes then you are or should be looking to them. As someone else posted, ALL of the rubber bushing are in need of replacement and have been for 150,000 miles now, along with shocks and all rubber brake lines and on and on.
You can figure about $7,000/$10,000 to bring the truck back to it's "glory days" so you have to figure out, do I need a HD truck and if so is it worth putting this much money into it. At this point only you know the answer to this question and if you asking, I would say no.
Don
Don
