996Pilot
Aug 26, 2019Explorer
bkenobi wrote:
The truck has factory 18" wheels. TorkLift suggested that if I added air bags, installing stable loads to engage the springs would help quite a bit. My truck requires drilling the springs for installation, so not sure I want to do that myself based on how hard that metal is and the resulting drill time at a bad angle.
I had to drill the 2006 RAM lowers. It was a piece of cake. I placed a block of wood on a floor jack with the drill motor placed onto the block of wood. Slowly raise the floor jack applying constant pressure at a moderately slow drill speed with some cutting oil - viola. Torklift gives you four drill bits (one for each spring) with the kit, I used one drill bit for all four. No worries. HOWEVER -- my 2015 RAM 3500 SRW had holes from the factory - no drilling required.
44,067 PostsLatest Activity: Jun 03, 2026
