rhagfo wrote:
dbbls wrote:
Look on the door post and air up accordingly.
Cummins12V98 wrote:
Weigh your combo loaded and TV seperately. Use tire weight/inflation chart.
My Ram 2500 4x4 Cummins empty 72 front 45 rear rotate about 15k. Michelins or BFG's I easily get over 100k on a set. I would guess for you 65 front.
I go with Cummins12V98 on this subject! The door post is for MAXIMUM load not daily driving. Running the rears at 70 empty, will;
shorten tire life
result in reduced traction in wet weather
result in harsher ride when empty
I also run about 45# empty, loaded about 70# (80# max pressure), loaded for bear my rear axle is about 5,200# tires rated at 6,830#.
Thanks!
The door numbers are CYA! I am not a sheep and use the tire inflation charts. That is why I get easily over 100K on my tires.
