RandyAmy wrote:
RAM 3500 dually that will soon have a TC on it.
It's a question of what should the rear tire pressure be and I'm wondering what you run your dually at. The camper should be around 4-5k pounds. I'm planning to install Crossfire Equalization and need a number...psi.
RAM said 65 psi
Tire manufacture,Nexen Roadian,said 80 psi
Both said 80 psi for the front.
Who's correct?
I can calculate it for you, but need weighed axle-loads , or better axle-end-loads.
The estimation you do is verry dangerous.
Also need 3 things of tires.
1. Maximum load or loadindex for dual, but give it all so also single.
2. Loadrange or better pressure behind AT .
3. Max speed of tire or speedcode.
As long as you dont have weighed loads fully loaded as you go on trip, we will have to use the GAWR's, also give GVWR.
And what configuration, drive axle duall we know, but alao TAG axle?
